Today I started by drilling the C-613 splice plates that join the Wd-716 forward canopy frame to the Wd-725 canopy side rails. Then I drilled the Wd-725 side rail aft angles where they attach to the F-631A aft canopy frame. Then I clamped the Wd-725 side rails to the aft canopy deck and match drilled the C-613 splice plate to it and the Wd-725 aft angle to the F-631A frame. Finishing up I match drilled the C-613 splice plate to the Wd-716 forward canopy frame.
